주요 콘텐츠로 건너뛰기
iRobot Roomba 880 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 1/3 iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 2/3 iRobot Roomba 880 Side Brush Motor Replacement, Side Brush Motor: 1 단계, 이미지 3/3
    • Remove the two Phillips #1 15mm screws holding the battery cover in place.
    • Once unscrewed, remove the battery cover and set aside.
  2. iRobot Roomba 880 Side Brush Motor Replacement: 2 단계, 이미지 1/3 iRobot Roomba 880 Side Brush Motor Replacement: 2 단계, 이미지 2/3 iRobot Roomba 880 Side Brush Motor Replacement: 2 단계, 이미지 3/3
    • Remove two 15mm Phillips #1 screws beneath each side wheel.
  3. iRobot Roomba 880 Side Brush Motor Replacement: 3 단계, 이미지 1/3 iRobot Roomba 880 Side Brush Motor Replacement: 3 단계, 이미지 2/3 iRobot Roomba 880 Side Brush Motor Replacement: 3 단계, 이미지 3/3
    • Remove the 10mm Phillips #1 screw holding the side brush in place.
    • Once unscrewed, remove the side brush and set aside.
  4. iRobot Roomba 880 Side Brush Motor Replacement: 4 단계, 이미지 1/1
    • Remove the outer covering.
  5. iRobot Roomba 880 Side Brush Motor Replacement: 5 단계, 이미지 1/2 iRobot Roomba 880 Side Brush Motor Replacement: 5 단계, 이미지 2/2
    • Remove the three 10mm Phillips #1 screws holding down the side brush motor case.
  6. iRobot Roomba 880 Side Brush Motor Replacement: 6 단계, 이미지 1/2 iRobot Roomba 880 Side Brush Motor Replacement: 6 단계, 이미지 2/2
    • Take out the side brush motor case.
  7. iRobot Roomba 880 Side Brush Motor Replacement: 7 단계, 이미지 1/1
    • Remove the 10mm Phillips #1 screw holding down the lid of the side brush motor case.
  8. iRobot Roomba 880 Side Brush Motor Replacement: 8 단계, 이미지 1/3 iRobot Roomba 880 Side Brush Motor Replacement: 8 단계, 이미지 2/3 iRobot Roomba 880 Side Brush Motor Replacement: 8 단계, 이미지 3/3
    • Remove the piece holding the lid to the case.
    • Take off the lid and set aside.
  9. iRobot Roomba 880 Side Brush Motor Replacement: 9 단계, 이미지 1/2 iRobot Roomba 880 Side Brush Motor Replacement: 9 단계, 이미지 2/2
    • Remove the three 10mm Phillips #1 screws.
  10. iRobot Roomba 880 Side Brush Motor Replacement: 10 단계, 이미지 1/3 iRobot Roomba 880 Side Brush Motor Replacement: 10 단계, 이미지 2/3 iRobot Roomba 880 Side Brush Motor Replacement: 10 단계, 이미지 3/3
    • Flip over and remove the side brush motor.
    • All done!
결론
다른 2명이 해당 안내서를 완성하였습니다.
agriewe
회원 가입일: 04/18/17
155 평판
안내서 1개 작성함
Cal Poly, Team S17-G4, Banghart Spring 2017 Cal Poly, Team S17-G4, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 1,566
