주요 콘텐츠로 건너뛰기
iRobot Roomba 891 Extractor Assembly Replacement
필요한 것
  1. iRobot Roomba 891 Extractor Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 iRobot Roomba 891 Extractor Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Extractor Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Extractor Assembly Replacement: 3 단계, 이미지 3개 중 1개 iRobot Roomba 891 Extractor Assembly Replacement: 3 단계, 이미지 3개 중 2개 iRobot Roomba 891 Extractor Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
  4. iRobot Roomba 891 Extractor Assembly Replacement, Side Brush: 4 단계, 이미지 2개 중 1개 iRobot Roomba 891 Extractor Assembly Replacement, Side Brush: 4 단계, 이미지 2개 중 2개
    • Remove the 7.5mm flat head #4 screw from center of the side brush.
  5. iRobot Roomba 891 Extractor Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the side brush off of the motor hub.
  6. iRobot Roomba 891 Extractor Assembly Replacement, Extractor Assembly: 6 단계, 이미지 1개 중 1개
    • Remove the dustbin assembly from the Roomba.
  7. iRobot Roomba 891 Extractor Assembly Replacement: 7 단계, 이미지 3개 중 1개 iRobot Roomba 891 Extractor Assembly Replacement: 7 단계, 이미지 3개 중 2개 iRobot Roomba 891 Extractor Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Unscrew the 2 phillips #2 11mm screws from roomba.
    • These captive screws will remain in the bottom cover after being loosened.
  8. iRobot Roomba 891 Extractor Assembly Replacement: 8 단계, 이미지 2개 중 1개 iRobot Roomba 891 Extractor Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the yellow tabs and lift the red cover from the extractor assembly.
  9. iRobot Roomba 891 Extractor Assembly Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the rollers from the assembly by lifting it out from right side.
  10. iRobot Roomba 891 Extractor Assembly Replacement: 10 단계, 이미지 2개 중 1개 iRobot Roomba 891 Extractor Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Close the cover and remove the four 11mm Phillips #00 screws from the assembly.
  11. iRobot Roomba 891 Extractor Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Grasp the center of the assembly and remove from the roomba.
결론
작성자
2다른 기여자 명과 함께
Justin Tolin
회원 가입일: 05/29/19
736 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 14
전체 시간: 756
