주요 콘텐츠로 건너뛰기
iRobot Roomba 891 Side Brush Motor Replacement
필요한 것
  1. iRobot Roomba 891 Side Brush Motor Replacement, Battery: 1 단계, 이미지 2개 중 1개 iRobot Roomba 891 Side Brush Motor Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Side Brush Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Side Brush Motor Replacement: 3 단계, 이미지 3개 중 1개 iRobot Roomba 891 Side Brush Motor Replacement: 3 단계, 이미지 3개 중 2개 iRobot Roomba 891 Side Brush Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
  4. iRobot Roomba 891 Side Brush Motor Replacement, Side Brush: 4 단계, 이미지 2개 중 1개 iRobot Roomba 891 Side Brush Motor Replacement, Side Brush: 4 단계, 이미지 2개 중 2개
    • Remove the 7.5mm flat head #4 screw from center of the side brush.
  5. iRobot Roomba 891 Side Brush Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the side brush off of the motor hub.
  6. iRobot Roomba 891 Side Brush Motor Replacement, Side Brush Motor: 6 단계, 이미지 1개 중 1개
    • Remove dustbin from Roomba.
  7. iRobot Roomba 891 Side Brush Motor Replacement: 7 단계, 이미지 2개 중 1개 iRobot Roomba 891 Side Brush Motor Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew 2 phillips #2 screws from the bottom cover.
    • Remove the bottom cover.
  8. iRobot Roomba 891 Side Brush Motor Replacement: 8 단계, 이미지 3개 중 1개 iRobot Roomba 891 Side Brush Motor Replacement: 8 단계, 이미지 3개 중 2개 iRobot Roomba 891 Side Brush Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew and remove the single 13mm Tri-point Y1 screw and retaining tab.
    • Loosen two captive Phillips #00 16mm screws.
  9. iRobot Roomba 891 Side Brush Motor Replacement: 9 단계, 이미지 2개 중 1개 iRobot Roomba 891 Side Brush Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Grasp motor module and remove from roomba.
결론
작성자
2다른 기여자 명과 함께
Justin Tolin
회원 가입일: 05/29/19
736 평판
안내서 5개를 작성함
1가이드 댓글
We did this whole process and it still doesn’t turn :0(
jeanne.curnuck - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 14
전체 시간: 501
