주요 콘텐츠로 건너뛰기
iRobot Roomba 960 Debris Extractor Replacement
필요한 것
  1. iRobot Roomba 960 Debris Extractor Replacement, Debris Extractor: 1 단계, 이미지 1/1
    • Turn the Roomba upside down and orient it so that the wheels are facing upwards and the dustbin is furthest from you.
  2. iRobot Roomba 960 Debris Extractor Replacement: 2 단계, 이미지 1/2 iRobot Roomba 960 Debris Extractor Replacement: 2 단계, 이미지 2/2
    • Pinch the two yellow tabs that are located near the dustbin towards each other to open the frame.
  3. iRobot Roomba 960 Debris Extractor Replacement: 3 단계, 이미지 1/1
    • Lift the frame to expose the two debris extractors.
  4. iRobot Roomba 960 Debris Extractor Replacement: 4 단계, 이미지 1/3 iRobot Roomba 960 Debris Extractor Replacement: 4 단계, 이미지 2/3 iRobot Roomba 960 Debris Extractor Replacement: 4 단계, 이미지 3/3
    • Carefully apply pressure to one side of the first debris extractor to release it. Lift to remove.
    • Do the same to the second debris extractor.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vanessa Greyson
회원 가입일: 02/02/17
471 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-3, Blackwell Spring 2017 USF Tampa, Team 16-3, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 20
전체 시간: 3,359
