주요 콘텐츠로 건너뛰기
iRobot Roomba 960 Filter Replacement
필요한 것
  1. iRobot Roomba 960 Filter Replacement, Filter: 1 단계, 이미지 1/1
    • Orient the Roomba so that the device is on its wheels and the words can be read from left to right.
  2. iRobot Roomba 960 Filter Replacement: 2 단계, 이미지 1/3 iRobot Roomba 960 Filter Replacement: 2 단계, 이미지 2/3 iRobot Roomba 960 Filter Replacement: 2 단계, 이미지 3/3
    • Press the large button on the Roomba that is located closest to you.
    • Pull to remove the dust bin.
  3. iRobot Roomba 960 Filter Replacement: 3 단계, 이미지 1/3 iRobot Roomba 960 Filter Replacement: 3 단계, 이미지 2/3 iRobot Roomba 960 Filter Replacement: 3 단계, 이미지 3/3
    • With the dust bin completely detached from the Roomba, press the tab that is located on your right (there is a yellow arrow pointing to it).
    • Lift the red plastic cover to access the filter.
  4. iRobot Roomba 960 Filter Replacement: 4 단계, 이미지 1/3 iRobot Roomba 960 Filter Replacement: 4 단계, 이미지 2/3 iRobot Roomba 960 Filter Replacement: 4 단계, 이미지 3/3
    • Using the yellow ribbon that is located at the top of the filter, pull it towards you.
    • Carefully remove the used filter.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vanessa Greyson
회원 가입일: 02/02/17
471 평판
안내서 3개 작성하였습니다
USF Tampa, Team 16-3, Blackwell Spring 2017 USF Tampa, Team 16-3, Blackwell Spring 2017 회원
USFT-BLACKWELL-S17S16G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
I need to replace the red bin cover over the filter, do I need to unscrew the black piece or something or just try to pry it out. I don’t want to break it.
Sandra Freed - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 2,123
