주요 콘텐츠로 건너뛰기
iRobot Roomba 980 Rear Wheels
필요한 것
  1. iRobot Roomba 980 Rear Wheels, Battery: 1 단계, 이미지 1/1
    • Flip over the device and remove the two 11.5 mm screws using the Phillips #1 screwdriver.
  2. iRobot Roomba 980 Rear Wheels: 2 단계, 이미지 1/2 iRobot Roomba 980 Rear Wheels: 2 단계, 이미지 2/2
    • Unscrew the back plate using a Phillips #1 screwdriver.
    • Carefully lift the panel up once the screws are removed.
  3. iRobot Roomba 980 Rear Wheels: 3 단계, 이미지 1/2 iRobot Roomba 980 Rear Wheels: 3 단계, 이미지 2/2
    • With both hands, grab the two black tabs on each end of the battery.
    • Pull the tabs upwards to remove the battery.
  4. iRobot Roomba 980 Rear Wheels, Rear Wheels: 4 단계, 이미지 1/2 iRobot Roomba 980 Rear Wheels, Rear Wheels: 4 단계, 이미지 2/2
    • Loosen the screw on the side brush.
    • Lift the side brush from the device.
  5. iRobot Roomba 980 Rear Wheels: 5 단계, 이미지 1/2 iRobot Roomba 980 Rear Wheels: 5 단계, 이미지 2/2
    • Unscrew the (2) 11.5mm screws using the Phillips #1 screwdriver.
    • Carefully remove the plate by lifting it off of the device.
  6. iRobot Roomba 980 Rear Wheels: 6 단계, 이미지 1/2 iRobot Roomba 980 Rear Wheels: 6 단계, 이미지 2/2
    • Removing the brush module may ease the removal of the wheel module
    • Locate the (3) 15.8mm gold Phillips #1 screws and unscrew them.
    • Lift the wheel module removing it from the vacuum.
    • Remove the other wheel by repeating these steps.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ernesto Rodriguez Romero
회원 가입일: 09/27/17
971 평판
안내서 4개 작성하였습니다
USF Tampa, Team S14-G2, Boczar Fall 2017 USF Tampa, Team S14-G2, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 17
전체 시간: 3,205
