주요 콘텐츠로 건너뛰기
iRobot Roomba Edge-Sweeping Brush Replacement
필요한 것
  1. iRobot Roomba Edge-Sweeping Brush Replacement, Loosen the edge brush screw: 1 단계, 이미지 1개 중 1개
    • Make sure your Roomba is turned off and flip it over to access its underside.
    • Use a Phillips screwdriver to loosen the single captive screw securing the edge-sweeping brush. Make sure to keep the brush from rotating while screwing.
    • This screw is a captive screw and therefore not removable.
  2. iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: 2 단계, 이미지 2개 중 1개 iRobot Roomba Edge-Sweeping Brush Replacement, Remove the edge brush: 2 단계, 이미지 2개 중 2개
    • Use your fingers to gather all three brush arms and grab them simultaneously.
    • Steadily pull upwards to release the brush from its hexagonal axle. You can gently rock it back and forth if it sits too tight.
결론
작성자
2다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
129,346 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 28
지난 30일: 112
전체 시간: 2,187
