주요 콘텐츠로 건너뛰기
iRobot Roomba e5 Brush Replacement
  1. iRobot Roomba e5 Brush Replacement, Brush: 1 단계, 이미지 1/1
    • Flip the Roomba upside down.
  2. iRobot Roomba e5 Brush Replacement: 2 단계, 이미지 1/2 iRobot Roomba e5 Brush Replacement: 2 단계, 이미지 2/2
    • Release the lock on the brushes using the green tab.
    • Lift the lock up from the end of the brushes.
  3. iRobot Roomba e5 Brush Replacement: 3 단계, 이미지 1/3 iRobot Roomba e5 Brush Replacement: 3 단계, 이미지 2/3 iRobot Roomba e5 Brush Replacement: 3 단계, 이미지 3/3
    • Remove both of the brushes.
    • When reassembling the brushes, make sure to insert the long end first.
    • The two long ends each have a different shape. One end is a square and one end is a rectangle.
    • You may have to rotate the brushes while inserting so that they snap into place.
결론
McKayla Davis
회원 가입일: 03/24/22
339 평판
안내서 3개 작성하였습니다
Casper College, Team 1-2, Lareau Spring 2022 Casper College, Team 1-2, Lareau Spring 2022 회원
CASC-LAREAU-S22S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 33
전체 시간: 802
