소개
This guide will help you replace the filter on the iRobot Roomba e5 (model number: e515020), a Roomba e series robot vacuum that is ideal for pet-friendly homes. Due to its capability in pet homes, the filter needs to be replaced once every two months (this can vary depending on how much your Roomba is being used). This is a simple four step process that requires no tools or previous experience. However, it can get a bit messy so it's best to replace the filter in an area where dirt is acceptable as the filter and vacuum will drop loose dirt often.
필요한 것
Flip the Roomba upside down so that the front wheel (caster wheel) is facing away from you.
Push the trash bin removal button on the side of the Roomba.
다른 2명이 해당 안내서를 완성하였습니다.
