주요 콘텐츠로 건너뛰기
iRobot Roomba i3 Plus Battery Replacement
필요한 것
  1. iRobot Roomba i3 Plus Battery Replacement, The Cover: 1 단계, 이미지 1개 중 1개
    • Unscrew the 5 #0 Phillips screws.
    • The screws do not come out all the way, they will stay in the cover.
  2. iRobot Roomba i3 Plus Battery Replacement, The Brush: 2 단계, 이미지 1개 중 1개
    • Use a Flathead screwdriver or Philips to unscrew the side brush.
    • Make sure to hold the side brush or it will spin when you try to unscrew it.
  3. iRobot Roomba i3 Plus Battery Replacement, Remove cover: 3 단계, 이미지 1개 중 1개
    • Gently pull the side brush straight up.
    • Do not pull the side brush too hard or you may break the plastic.
  4. iRobot Roomba i3 Plus Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use your fingernails to pull up on each side to remove the cover.
    • If there is resistance, Do not pull hard, just find what screw is not all the way unscrewed.
  5. iRobot Roomba i3 Plus Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Pull back the clip in the middle and pull the battery straight up.
    • When assembling the Roomba again. put the robot on its charging base to wake it up.
  6. iRobot Roomba i3 Plus Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Line the battery up with the notches and side it in.
결론
To reassemble your Roomba, follow these instructions in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Hunter Platt
회원 가입일: 01/29/23
210 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 33
전체 시간: 633
