주요 콘텐츠로 건너뛰기
iRobot Roomba i7 Front Bumper Replacement
필요한 것
  1. iRobot Roomba i7 Front Bumper Replacement, Front Bumper: 1 단계, 이미지 3개 중 1개 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: 1 단계, 이미지 3개 중 2개 iRobot Roomba i7 Front Bumper Replacement, Front Bumper: 1 단계, 이미지 3개 중 3개
    • Flip the iRobot Roomba i7 so that the underside is facing upwards.
    • Using a Phillips #1 screwdriver, unscrew the 6.27mm screw in the center of the side brush.
    • Using a Phillips #1 screwdriver, unscrew the 5 screws surrounding the bottom cover of the Roomba
  2. iRobot Roomba i7 Front Bumper Replacement: 2 단계, 이미지 3개 중 1개 iRobot Roomba i7 Front Bumper Replacement: 2 단계, 이미지 3개 중 2개 iRobot Roomba i7 Front Bumper Replacement: 2 단계, 이미지 3개 중 3개
    • Use the Philips #1 screw driver to remove the ten, 4.17 mm screws on the dislodged Bumper
  3. iRobot Roomba i7 Front Bumper Replacement: 3 단계, 이미지 2개 중 1개 iRobot Roomba i7 Front Bumper Replacement: 3 단계, 이미지 2개 중 2개
    • Once removed, readjust the bumper into its appropriate placement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Nikolas
회원 가입일: 01/30/20
153 평판
안내서 1개를 작성함
2가이드 댓글
My roomba seems to be blind some tomes it starts and just keeps on running into the walls over and over again sometime i rebbot it and it works and other times it doesnt work i dont know what wrong with it. Its a roomba i7+ 3 years old.
John Flannery - 답글
My Roomba will run until it hits the wall and then runs backwards. Help
beverly vernon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 70
지난 30일: 278
전체 시간: 17,028
