주요 콘텐츠로 건너뛰기
iRobot Looj 120 Controller Buttons Replacement
필요한 것
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: 1 단계, 이미지 1/1
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: 2 단계, 이미지 1/1
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: 3 단계, 이미지 1/1
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: 4 단계, 이미지 1/1
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lucas Otto
회원 가입일: 11/12/14
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 216
