주요 콘텐츠로 건너뛰기
iRobot looj 120 Rear Motor Replacement
필요한 것
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: 1 단계, 이미지 1/1
    • Remove the four exterior screws
결론
Joshua
회원 가입일: 10/24/14
631 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G5
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 227
