주요 콘텐츠로 건너뛰기
소개
For this guide you will be removing rear wheels, then removing the outer shell and then replacing the motor.
부품
지정된 부품이 없습니다.
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: 1 단계, 이미지 1/1
    • Remove the four exterior screws
결론
Joshua
회원 가입일: 2014년 10월 24일
631 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 2-5, Duarte Fall 2014 UMass Dartmouth, Team 2-5, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G5
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 209
