주요 콘텐츠로 건너뛰기
iVIEW-754TPC Logic Board Replacement
필요한 것
  1. iVIEW-754TPC Logic Board Replacement, Rear Panel: 1 단계, 이미지 3개 중 1개 iVIEW-754TPC Logic Board Replacement, Rear Panel: 1 단계, 이미지 3개 중 2개 iVIEW-754TPC Logic Board Replacement, Rear Panel: 1 단계, 이미지 3개 중 3개
    • Before disassembling your tablet, make sure it is powered off.
    • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  2. iVIEW-754TPC Logic Board Replacement, Remove Battery: 2 단계, 이미지 3개 중 1개 iVIEW-754TPC Logic Board Replacement, Remove Battery: 2 단계, 이미지 3개 중 2개 iVIEW-754TPC Logic Board Replacement, Remove Battery: 2 단계, 이미지 3개 중 3개
    • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
    • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  3. iVIEW-754TPC Logic Board Replacement, Camera Assembly: 3 단계, 이미지 3개 중 1개 iVIEW-754TPC Logic Board Replacement, Camera Assembly: 3 단계, 이미지 3개 중 2개 iVIEW-754TPC Logic Board Replacement, Camera Assembly: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • The camera module is located directly under the top right corner of the back cover.
    • Peel back the tape holding down the camera ribbon connector using a pair of tweezers.
    • As you peel the tape backward, the front facing camera may come out, this is not an issue.
    • If the front facing camera does not come out, gently lift it out with a pair of tweezers
  4. iVIEW-754TPC Logic Board Replacement, Remove Camera: 4 단계, 이미지 2개 중 1개 iVIEW-754TPC Logic Board Replacement, Remove Camera: 4 단계, 이미지 2개 중 2개
    • Use a spudger to lift flap on top of the camera ZIF adapter.
    • At this point the camera module can be easily removed with a pair of tweezers.
    • During reassembly, make sure you put the ZIF adapter snugly back into its socket and secure the flap.
  5. iVIEW-754TPC Logic Board Replacement, Logic Board: 5 단계, 이미지 1개 중 1개
    • Remove the four 2.2mm Phillips screws holding the logic board in place. Place the screws on the iFixit magnetic project mat.
  6. iVIEW-754TPC Logic Board Replacement, WIFI Antenna: 6 단계, 이미지 2개 중 1개 iVIEW-754TPC Logic Board Replacement, WIFI Antenna: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Gently peel the WIFI Antenna up using a pair of tweezers.
  7. iVIEW-754TPC Logic Board Replacement, Disconnect LCD: 7 단계, 이미지 3개 중 1개 iVIEW-754TPC Logic Board Replacement, Disconnect LCD: 7 단계, 이미지 3개 중 2개 iVIEW-754TPC Logic Board Replacement, Disconnect LCD: 7 단계, 이미지 3개 중 3개
    • Use a spudger to lift the flap on top of the LCD ZIF socket.
    • Gently remove the ribbon cable from the socket using a tweezers.
  8. iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: 8 단계, 이미지 3개 중 1개 iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: 8 단계, 이미지 3개 중 2개 iVIEW-754TPC Logic Board Replacement, Disconnect Digitizer: 8 단계, 이미지 3개 중 3개
    • Use a spudger to lift the flap on top of the digitizer ZIF socket.
    • Gently pull the tape attached to the ribbon cable to remove the cable from its socket.
  9. iVIEW-754TPC Logic Board Replacement, Remove Logic Board: 9 단계, 이미지 3개 중 1개 iVIEW-754TPC Logic Board Replacement, Remove Logic Board: 9 단계, 이미지 3개 중 2개 iVIEW-754TPC Logic Board Replacement, Remove Logic Board: 9 단계, 이미지 3개 중 3개
    • Gently slide the spudger below the logic board at the left side nearest the battery. Lift upward and away from the power button and bottom connectors.
    • The battery is still attached to the logic board. Be careful to not tear the two apart during removal.
결론
작성자
2다른 기여자 명과 함께
Robert Clark
회원 가입일: 01/21/15
1,065 평판
안내서 7개를 작성함
USF Tampa, Team 5-4, Brown Winter 2015 USF Tampa, Team 5-4, Brown Winter 2015 회원
USFT-BROWN-W15S5G4
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 1,048
