주요 콘텐츠로 건너뛰기
ilo 1Gb Mp3 Player External volume button and hold switch Replacement
필요한 것
  1. ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Belt Clip: 1 단계, 이미지 1/2 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Belt Clip: 1 단계, 이미지 2/2
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Battery Cover: 2 단계, 이미지 1/3 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Battery Cover: 2 단계, 이미지 2/3 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Battery Cover: 2 단계, 이미지 3/3
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Battery: 3 단계, 이미지 1/2 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
  4. ilo 1Gb Mp3 Player External volume button and hold switch Replacement, ilo 1 Gb Mp3 Player Motherboard: 4 단계, 이미지 1/2 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, ilo 1 Gb Mp3 Player Motherboard: 4 단계, 이미지 2/2
    • Under the cover you will find Three (3) 5mm screws that will need to be removed. For this you will need to use the PH00 screw tip included in your iFixit kit. Make sure to keep track of these screws as they will need to be reinserterd during the reassembly of your device.
    • These screws are different from the two other screws from the interior
  5. ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 5 단계, 이미지 1/3 ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 5 단계, 이미지 2/3 ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 5 단계, 이미지 3/3
    • Separate the front housing from the back housing using your thumbs. Carefully pry around the edge of the bottom of device then be sure to unhook the clip inside just below the hold switch.
  6. ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 6 단계, 이미지 1/2 ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 6 단계, 이미지 2/2
    • Once you have removed the front housing and exposed the internal board and screen locate and Remove the Two (2) 4mm PH00 screws on the board.
    • One is located in the top middle above the screen and the other is located at the bottom left between the Stop and Back buttons.
  7. ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 7 단계, 이미지 1/2 ilo 1Gb Mp3 Player External volume button and hold switch Replacement: 7 단계, 이미지 2/2
    • Once those screws are removed, gently remove the board from the rear casing.
    • When installing the motherboard into the case be especially careful with the headphone and USB jacks located at the top of the motherboard. These should be slid into their sockets first.
  8. ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Volume Rocker: 8 단계, 이미지 1/2 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Volume Rocker: 8 단계, 이미지 2/2
    • Remove the Volume button from its rocker socket by gently pushing in on the button until it pops out if the two sockets.
  9. ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Hold Switch: 9 단계, 이미지 1/3 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Hold Switch: 9 단계, 이미지 2/3 ilo 1Gb Mp3 Player External volume button and hold switch Replacement, Hold Switch: 9 단계, 이미지 3/3
    • Remove Hold Switch from Socket by squeezing the prongs that hold the button in the socket together and push the button outward.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joe
회원 가입일: 06/04/13
291 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 630
