주요 콘텐츠로 건너뛰기
ilo 1Gb Mp3 Player SD Card Replacement
필요한 것
  1. ilo 1Gb Mp3 Player SD Card Replacement, Belt Clip: 1 단계, 이미지 1/2 ilo 1Gb Mp3 Player SD Card Replacement, Belt Clip: 1 단계, 이미지 2/2
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. ilo 1Gb Mp3 Player SD Card Replacement, Battery Cover: 2 단계, 이미지 1/3 ilo 1Gb Mp3 Player SD Card Replacement, Battery Cover: 2 단계, 이미지 2/3 ilo 1Gb Mp3 Player SD Card Replacement, Battery Cover: 2 단계, 이미지 3/3
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. ilo 1Gb Mp3 Player SD Card Replacement, Battery: 3 단계, 이미지 1/2 ilo 1Gb Mp3 Player SD Card Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
  4. ilo 1Gb Mp3 Player SD Card Replacement, SD Card: 4 단계, 이미지 1/2 ilo 1Gb Mp3 Player SD Card Replacement, SD Card: 4 단계, 이미지 2/2
    • The SD Card slot is located under the battery case indicated here.
    • The SD Card Slides into the slot as depicted in the photo and on the indicator above the slot.
    • The ilo 1Gb Mp3 Player was only designed to accept SD Cards of 512mb or lower.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
tjkurt01
회원 가입일: 06/04/13
306 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 8
전체 시간: 421
