주요 콘텐츠로 건너뛰기
ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement
필요한 것
  1. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Belt Clip: 1 단계, 이미지 1/2 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Belt Clip: 1 단계, 이미지 2/2
    • Remove the belt clip by pulling the clip casing up and away from the device starting at the top over the slightly protruding headphones jack.
  2. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: 2 단계, 이미지 1/3 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: 2 단계, 이미지 2/3 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery Cover: 2 단계, 이미지 3/3
    • Remove the battery cover by gently pushing inward on the arrow on the cover.
    • While maintaining pressure push the cover upward.
  3. ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery: 3 단계, 이미지 1/2 ilo 1Gb Mp3 Player ilo Mp3 Player Battery and Case Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the Battery from the socket
    • When installing the battery take note of the signs displayed in the socket to determine which direction the negative and positive ends should be.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joe
회원 가입일: 06/04/13
291 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 345
