주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iodyne Pro Data Memory Module Replacement
필요한 것
  1. iodyne Pro Data Memory Module Replacement, Remove Service Panel Screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
    댓글 쓰기
  2. iodyne Pro Data Memory Module Replacement, Dislodge Service Panel: 2 단계, 이미지 3개 중 1개 iodyne Pro Data Memory Module Replacement, Dislodge Service Panel: 2 단계, 이미지 3개 중 2개 iodyne Pro Data Memory Module Replacement, Dislodge Service Panel: 2 단계, 이미지 3개 중 3개
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
    댓글 쓰기
  3. iodyne Pro Data Memory Module Replacement, Remove screw covers: 3 단계, 이미지 1개 중 1개
    • Remove the four screw covers and place them upside down on a clean surface for later application during reassembly.
    댓글 쓰기
  4. iodyne Pro Data Memory Module Replacement, Unfasten vent panel: 4 단계, 이미지 2개 중 1개 iodyne Pro Data Memory Module Replacement, Unfasten vent panel: 4 단계, 이미지 2개 중 2개
    • Unscrew the four T4 Torx screws revealed beneath the rubber feet.
    • Grab Pro Data around the vent panel to prevent it from dropping, and flip the chassis right side up.
    댓글 쓰기
  5. iodyne Pro Data Memory Module Replacement, Remove vent panel: 5 단계, 이미지 2개 중 1개 iodyne Pro Data Memory Module Replacement, Remove vent panel: 5 단계, 이미지 2개 중 2개
    • Remove the vent panel by lifting directly up to dislodge it from the brace.
    댓글 쓰기
  6. iodyne Pro Data Memory Module Replacement, Unfasten heatsink: 6 단계, 이미지 2개 중 1개 iodyne Pro Data Memory Module Replacement, Unfasten heatsink: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Incrementally unfasten the two sprung screws using a 3mm flathead screwdriver, being careful not to let the driver slip out and damage other motherboard components. These screws are retained with the heatsink as it removed.
    댓글 쓰기
  7. iodyne Pro Data Memory Module Replacement, Remove heatsink: 7 단계, 이미지 2개 중 1개 iodyne Pro Data Memory Module Replacement, Remove heatsink: 7 단계, 이미지 2개 중 2개
    • Gently remove the heatsink from its socket by lifting directly up, revealing the Memory module underneath.
    댓글 쓰기
  8. iodyne Pro Data Memory Module Replacement, Remove heatsink thermal pad: 8 단계, 이미지 1개 중 1개
    • Using a spudger or non-metal tool, remove the thermal pad from the heatsink. Replace this with the 1.5mm thermal pad provided with the replacement Memory module kit.
    댓글 쓰기
  9. iodyne Pro Data Memory Module Replacement, Remove Memory module: 9 단계, 이미지 2개 중 1개 iodyne Pro Data Memory Module Replacement, Remove Memory module: 9 단계, 이미지 2개 중 2개
    • Push the two retaining clips away from the Memory module to allow it to spring up at an angle.
    • Carefully remove the Memory module by gripping both short sides and pulling away from its socket at an angle. This will reveal a second thermal pad attached to the motherboard.
    댓글 쓰기
  10. iodyne Pro Data Memory Module Replacement, Remove motherboard thermal pad: 10 단계, 이미지 2개 중 1개 iodyne Pro Data Memory Module Replacement, Remove motherboard thermal pad: 10 단계, 이미지 2개 중 2개
    • Using a spudger or non-metal tool, remove the thermal pad from the motherboard. Replace this with the 2mm thermal pad provided with the replacement Memory module kit.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
iodyne
회원 가입일: 01/01/22
462 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 35
전체 시간: 448
