주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iodyne Pro Data SSD Module Replacement
필요한 것
  1. iodyne Pro Data SSD Module Replacement, Remove Service Panel Screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    • Make sure Pro Data is disconnected from power and Thunderbolt, then set it upside down on an anti-static mat or flat surface with appropriate protection from electrostatic discharge, such as an anti-static wrist strap.
    • Using a #2 Phillips screwdriver, remove the two screws securing the service panel into place.
    댓글 쓰기
  2. iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: 2 단계, 이미지 3개 중 1개 iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: 2 단계, 이미지 3개 중 2개 iodyne Pro Data SSD Module Replacement, Dislodge Service Panel: 2 단계, 이미지 3개 중 3개
    • Turn Pro Data over to the top side. Grip the chassis from the long sides, and push the service panel slightly down and away from the vent. It should slide about 5mm or .2" before stopping.
    • Grab the service panel from the left edge and lift up about 30°, dislodging its tabs from the vent, and remove to reveal the chassis interior.
    댓글 쓰기
  3. iodyne Pro Data SSD Module Replacement, Unfasten SSD module: 3 단계, 이미지 2개 중 1개 iodyne Pro Data SSD Module Replacement, Unfasten SSD module: 3 단계, 이미지 2개 중 2개
    • Identify the SSD module for replacement and note its retaining screw on the chassis perimeter.
    • Unfasten and remove the retention screw for the SSD module to be replaced using a #2 Phillips screwdriver.
    댓글 쓰기
  4. iodyne Pro Data SSD Module Replacement, Remove SSD module: 4 단계, 이미지 3개 중 1개 iodyne Pro Data SSD Module Replacement, Remove SSD module: 4 단계, 이미지 3개 중 2개 iodyne Pro Data SSD Module Replacement, Remove SSD module: 4 단계, 이미지 3개 중 3개
    • Lift the outer edge of the SSD module to a 15° angle from the motherboard.
    • Pull the SSD module up and away from its port to remove.
    • Insert the new SSD module at the same angle, then lower it into position and fasten its retention screw.
    댓글 쓰기
  5. iodyne Pro Data SSD Module Replacement, Validate repair: 5 단계, 이미지 1개 중 1개
    • After reassembling the chassis by following the steps in this guide in reverse, verify that the new SSD module is recognized and healthy by launching iodyne from the Applications folder and navigating to the Status tab.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order, then validate that the replacement SSD module is healthy by launching iodyne.app and navigating to the Status tab.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
iodyne
회원 가입일: 01/01/22
462 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 558
