주요 콘텐츠로 건너뛰기
ionvac SmartClean V2 Bumper Sensor Replacement
필요한 것
  1. ionvac SmartClean V2 Bumper Sensor Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Bumper Sensor Replacement, Shell (Top & Bottom): 1 단계, 이미지 2개 중 2개
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. Using a magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac right-side up, turning it so that the front filter vents are facing forward and the power button is furthest from you.
  2. ionvac SmartClean V2 Bumper Sensor Replacement: 2 단계, 이미지 3개 중 1개 ionvac SmartClean V2 Bumper Sensor Replacement: 2 단계, 이미지 3개 중 2개 ionvac SmartClean V2 Bumper Sensor Replacement: 2 단계, 이미지 3개 중 3개
    • Use a Phillips screwdriver to remove the 8 screws indicated in red holding the base together.
    • Use the same screwdriver to remove the 8 screws indicated in orange which hold the rims (bumper arms).
    • Remove the rims from your ionvac and set them aside.
  3. ionvac SmartClean V2 Bumper Sensor Replacement: 3 단계, 이미지 1개 중 1개
    • Flip your ionvac right-side up and tilt it upwards at a 45 degree angle.
    • Use a Jimmy or prying tool to wedge the sharp end through the bottom crevice (below the sensors).
    • Continue prying the outside rim of your ionvac open. You will feel the top shell (frame or cover) loosen.
    • Caution: Resist the urge to tear the top shell open until the entire rim has been loosened.
  4. ionvac SmartClean V2 Bumper Sensor Replacement: 4 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Bumper Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the top shell off carefully.
  5. ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: 5 단계, 이미지 3개 중 1개 ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: 5 단계, 이미지 3개 중 2개 ionvac SmartClean V2 Bumper Sensor Replacement, Bumper Sensor: 5 단계, 이미지 3개 중 3개
    • Turn your ionvac so that the sensor and the metal bumper piece are facing forward.
    • Gently lift and remove the bumper for cleaning or replacement.
결론
작성자
1다른 기여자 명과 함께
Ruth Mekonnen
회원 가입일: 09/11/23
767 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 17
전체 시간: 453
