소개
You should firstly follow first instruction how to open the device before proceeed to this instruction.
Pay attention to the precautions mentioned in the guide.
필요한 것
First ensure your laptop is turned off and check if you have the necessary tools
Be careful to don't touch if not necessary any electrical part of the product and insure you're properly grounding.
Gently remove the battery.
CAUTION!!
Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
SAFETY WARNING!
Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
다른 한 분이 해당 안내서를 완성하였습니다.
