필요한 것
After remove the battery, you need to remove the black mylar that covers keyboard connector.
Under the I/O board there's a hole that you need to insert a tool and push the keyboard at the same time you pull the plastic as show in the picture. This plastic holds the keyboard.
There are more holders, but you just need to open one, the others will sag when you pull the keyboard smoothly
다른 한 분이 해당 안내서를 완성하였습니다.
