소개
If you want to replace the motherboard of your ring Indoor Cam, then this is the guide for you.
As you will be working with electrical wires and components, make sure the device is not connected to power and use ESD-safe tools to avoid electrical injuries. Be sure to handle the motherboard delicately to avoid damaging the small electrical components.
필요한 것
Gently remove the three white leads from their sockets on the top of the motherboard.
거의 끝나갑니다!
결론
