주요 콘텐츠로 건너뛰기
samsung x820 LCD Replacement
필요한 것
  1. samsung x820 LCD Replacement, LCD: 1 단계, 이미지 1/3 samsung x820 LCD Replacement, LCD: 1 단계, 이미지 2/3 samsung x820 LCD Replacement, LCD: 1 단계, 이미지 3/3
    • samsung sgh x820
  2. samsung x820 LCD Replacement: 2 단계, 이미지 1/3 samsung x820 LCD Replacement: 2 단계, 이미지 2/3 samsung x820 LCD Replacement: 2 단계, 이미지 3/3
    • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  3. samsung x820 LCD Replacement: 3 단계, 이미지 1/3 samsung x820 LCD Replacement: 3 단계, 이미지 2/3 samsung x820 LCD Replacement: 3 단계, 이미지 3/3
    • now we have two more screws hiden
    • first time i used needle. this time i took a blade.
    • removing the last two philipps-head screws.
  4. samsung x820 LCD Replacement: 4 단계, 이미지 1/1
    • be carefull. the phone is thin and you should push on two hooks two open cover case.
  5. samsung x820 LCD Replacement: 5 단계, 이미지 1/1
    • now you should take of the square metal in the middle of your phone to eject display.
    • i used plastic spudger
  6. samsung x820 LCD Replacement: 6 단계, 이미지 1/1
    • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
결론
다른 3명이 해당 안내서를 완성하였습니다.
sergeygraf
회원 가입일: 10/24/10
161 평판
안내서 1개 작성함
댓글 한 개
How can I fix with button cos it is damaged
Tangkidos Hagame - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,575
