이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
now we have two more screws hiden
first time i used needle. this time i took a blade.
removing the last two philipps-head screws.
be carefull. the phone is thin and you should push on two hooks two open cover case.
now you should take of the square metal in the middle of your phone to eject display.
i used plastic spudger
the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
다른 3명이 해당 안내서를 완성하였습니다.
