소개
Before attempting to remove the phone's battery, make sure the phone is off. If the won't won't turn off, make sure to use caution when removing the battery.
도구
부품
부품은 필요하지 않습니다.
This is the back of the phone.
Using your other eight fingers to cradle the phone, place each thumb on either side of the "Alltell" symbol.
Apply pressure towards your fingers, and then towards the top of the phone in a single movement.
If the battery is not working properly, water damage might be the culprit.
The small box on the right contains a white background with red hashes on top.
If the lines are sharp, there has been no forms of water damage.
If lines are blurry, or the background is pinkish, the has been water damage.
