소개
This guide shows how to remove and replace an inner tube of a tire. This process may difficult he first time it is attempted.
필요한 것
Remove the flat tire by loosening and removing the axle nut with a 19 mm wrench.
Unscrew the axle bolt with a 19 mm socket wrench.
Remove the axle bolt from hole and remove the wheel from the wheelchair.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
