주요 콘텐츠로 건너뛰기
the Nokia 6230b Speaker Replacement
필요한 것
  1. the Nokia 6230b Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Press down the button on the back panel.
  2. the Nokia 6230b Speaker Replacement: 2 단계, 이미지 1/2 the Nokia 6230b Speaker Replacement: 2 단계, 이미지 2/2
    • Push the back cover upwards.
  3. the Nokia 6230b Speaker Replacement: 3 단계, 이미지 1/2 the Nokia 6230b Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the back cover from the phone.
  4. the Nokia 6230b Speaker Replacement, Front Cover: 4 단계, 이미지 1/1
    • Press the silver button on the top of the phone.
  5. the Nokia 6230b Speaker Replacement: 5 단계, 이미지 1/1
    • Slide your thumbnail down the case seam to separate the rest of the case.
  6. the Nokia 6230b Speaker Replacement: 6 단계, 이미지 1/1
    • Gently remove the case.
    • Careful! Do not bend the plastic tabs.
  7. the Nokia 6230b Speaker Replacement, Motherboard: 7 단계, 이미지 1/2 the Nokia 6230b Speaker Replacement, Motherboard: 7 단계, 이미지 2/2
    • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  8. the Nokia 6230b Speaker Replacement: 8 단계, 이미지 1/2 the Nokia 6230b Speaker Replacement: 8 단계, 이미지 2/2
    • Remove the panel that covers the motherboard.
    • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  9. the Nokia 6230b Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the LCD screen frame.
  10. the Nokia 6230b Speaker Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard.
  11. the Nokia 6230b Speaker Replacement, Speaker: 11 단계, 이미지 1/1
    • Locate the speaker on the back of the removed panel.
  12. the Nokia 6230b Speaker Replacement: 12 단계, 이미지 1/1
    • Use nails to gently lift the speaker up; speaker may be slightly glued to the panel.
  13. the Nokia 6230b Speaker Replacement: 13 단계, 이미지 1/1
    • When the speaker is loose, gently lift the speaker out of the panel.
결론
Job Jao
회원 가입일: 10/08/10
37 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-27, Regan Fall 2010 Cal Poly, Team 3-27, Regan Fall 2010 회원
CPSU-REGAN-F10S3G27
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 2,772
