주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
the Panasonic Lumix DMC-FX01 Camera Lens Replacement
필요한 것
  1. the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 2 단계, 이미지 1/1
    • Open the battery latch, and slide the battery release lever to the right.
  3. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 3 단계, 이미지 1/1
    • Remove the battery from the camera.
  4. the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Rear Casing: 4 단계, 이미지 1/1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 5 단계, 이미지 1/1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 6 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 6 단계, 이미지 2/2
    • Remove the left side casing.
  7. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 7 단계, 이미지 1/1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 8 단계, 이미지 1/1
    • Remove the bottom right panel.
  9. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 9 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 9 단계, 이미지 2/2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: 10 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Front Casing: 10 단계, 이미지 2/2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  11. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 11 단계, 이미지 1/3 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 11 단계, 이미지 2/3 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 11 단계, 이미지 3/3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  12. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 12 단계, 이미지 1/1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
  13. the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: 13 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Lens Assembly: 13 단계, 이미지 2/2
    • Remove the three black 5mm screws attached to the lens frame.
  14. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 14 단계, 이미지 1/1
    • Remove the lens frame.
  15. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 15 단계, 이미지 1/1
    • Lift out the circuit board as shown.
  16. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 16 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 16 단계, 이미지 2/2
    • Lift the two black latches that hold the connector ribbons in place.
    • Disconnect the two ribbons.
  17. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 17 단계, 이미지 1/1
    • Remove the lens assembly as shown.
  18. the Panasonic Lumix DMC-FX01 Camera Lens Replacement, Camera Lens: 18 단계, 이미지 1/1
    • Remove four 4mm screws from the lens assembly.
  19. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 19 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 19 단계, 이미지 2/2
    • Carefully turn over the assembly.
  20. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 20 단계, 이미지 1/2 the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 20 단계, 이미지 2/2
    • Remove the Fixed Frame Unit by separating it from the assembly.
    • Remove the Direct Frame Unit from the assembly.
  21. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 21 단계, 이미지 1/1
    • Remove the 1st lens frame from the lens assembly.
  22. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 22 단계, 이미지 1/1
    • Detach the 2nd Frame Unit from the assembly.
  23. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 23 단계, 이미지 1/1
    • Remove the 4mm screw from the lens housing.
  24. the Panasonic Lumix DMC-FX01 Camera Lens Replacement: 24 단계, 이미지 1/1
    • Separate the lens housing.
    • Replace the lens by gently prying away from the assembly.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Caleb Fink
회원 가입일: 10/11/10
191 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-22, Regan Fall 2010 Cal Poly, Team 9-22, Regan Fall 2010 회원
CPSU-REGAN-F10S9G22
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 21
전체 시간: 12,728
