이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Open the battery latch, and slide the battery release lever to the right.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
Gently remove the back casing.
Start at the bottom and carefully pry towards the top to get this piece free.
Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
Carefully remove the upper assembly, which houses the buttons and the flash battery.
Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
Lift the two black latches that hold the connector ribbons in place.
Disconnect the two ribbons.
Remove four 4 mm screws from the lens assembly using the Phillips #00 screwdriver.
Separate the fixed frame unit from the main lens assembly.
Separate the direct frame unit from the main lens assembly.
Remove the 4m m screw from the lens housing using the Phillips #00 screwdriver.
Separate the lens housing.
Replace the lens by gently prying away from the assembly.
다른 4명이 해당 안내서를 완성하였습니다.
