주요 콘텐츠로 건너뛰기
Galaxy S9 Plus Moisture Detected Fix
1 단계 번역중
1 단계
Galaxy S9 Plus Moisture Detected Fix: 0 단계, 이미지 1개 중 1개
  • The Phone checks for unwanted resistance on two of the pins on the usb-c charge connector on the phone. If there is water or too much moisture present in the connector, it will trigger a warning/audio beep - and disable charging.
  • The water present check is performed when charger is inserted.
  • Salt water, or water with clorine is absolutely not good for the connector. Should it happen - DO NOT CHARGE VIA THE CONNECTOR. clean and dry it before charging. This can save the connector/phone.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
