주요 콘텐츠로 건너뛰기
MacBook Unibody Model A1278 Front Display Glass Replacement
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 5개에 영향을 미칩니다.
1 단계 번역중
1 단계
MacBook Unibody Model A1278 Front Display Glass Replacement: 0 단계, 이미지 2개 중 1개 MacBook Unibody Model A1278 Front Display Glass Replacement: 0 단계, 이미지 2개 중 2개
  • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display. The area the adhesive is applied to is shown in red in the second picture.
  • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
  • Always aim the heat gun away from the soft rubber strip around the display glass. Heating the rubber will cause it to melt slightly, turning its finish from matte to glossy. Touching overheated rubber can cause it to permanently deform.
  • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
여기에 번역 삽입
귀하의 기여는 오픈 소스 Createive Commons 라이선스 하에 허가되었습니다.
