주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 2개에 영향을 미칩니다.
영어
프랑스어
16 단계 번역 중
16 단계
Verify that your iMac is turned off and unplugged from power before you continue. After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
  • Verify that your iMac is turned off and unplugged from power before you continue.
  • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
  • Remove the film from the 15 strip by reaching in from above and pulling the tab straight up from the bottom edge of the display.
Surtout ne pas abaisser complètement l'écran dans cette étape ; il restent encore deux câbles à attacher. Une fois que vous avez fixé l'écran vers le bas, vous ne serez pas en mesure de le soulever à nouveau sans endommager l'adhésif.
Poser le bord inférieur du verre de l'écran contre le haut du joint inférieur. Assurez-vous d'aligner les bords de l'écran avec les bords du boîtier arrière.
[* icon_caution] '''Do not '''fully lower the display in this step; there are still two cablesVerify that must be attached. Once you've set the display down,your iMac is turned off and unplugged from power before you won't be able to lift it again without damaging the adhesivecontinue.
[* black] LayAfter confirming that your iMac functions properly, disconnect the bottom edge ofdisplay cables and carefully lean the display glass againstforward.
[* black] Remove
the top offilm from the lower bezel. Be sure to align15 strip by reaching in from above and pulling the edges oftab straight up from the display with the edgesbottom edge of the rear casedisplay.
[* black] Remove
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
