주요 콘텐츠로 건너뛰기
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 80개에 영향을 미칩니다.
영어
프랑스어
1 단계 번역 중
1 단계
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
  • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
  • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
  • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Si la charnière n'est pas bloquée, l'iMac sera mal équilibré et vous aurez du mal à le manipuler. Les réparations sont plus rapides et simplifiées avec une cale de maintien pour iMac, mais sont possibles sans.
Avant de commencer à travailler sur votre iMac : Débranchez l'ordinateur et appuyez sur le bouton de mise sous tension pendant dix secondes afin de décharger les condensateurs de l'alimentation.
Veillez à ne toucher ni les fils des condensateurs ni les soudures apparentes à l'arrière du bloc d'alimentation. Tenez toujours la carte par les côtés.
[* icon_note] With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an [product|IF145-224|iMac service wedge|new_window=true], but can be completed without one.
+ [* icon_note] If you are using the [product|IF145-470|iFixit cardboard service wedge], follow [guide|136068|these assembly directions] to put it together.
[* black] ***Before beginning any work on your iMac:*** Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
[* icon_caution] ***Be very careful*** not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
