주요 콘텐츠로 건너뛰기
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 포함하는 안내서 80개에 영향을 미칩니다.
영어
프랑스어
3 단계
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
  • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
  • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
  • Run the tool up along the left side of the display.
Servez-vous de l'outil comme d'une roulette à pizza, en suivant le pourtour de l'iMac, de manière à effectuer une découpe au centre de la mousse adhésive.
Veillez à toujours pousser l'outil en plaçant la poignée derrière la roulette. Si vous tirez sur l'outil, la roulette risque de sortir de la poignée.
Passez l'outil de haut en bas sur le côté gauche de l'écran.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
