주요 콘텐츠로 건너뛰기
알림: 귀하는 선행 작업 안내서를 편집하고 계십니다. 변경된 사항들은 이 선행 작업 단계를 사용하는 안내서에 영향을 미칩니다.
영어
프랑스어
1 단계 번역 중
1 단계
Examine your replacement part, and your original display carefully to be sure they match. Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component. Desolder the four solder pads from the lower left of the display to remove the sensor assembly cable.
  • Examine your replacement part, and your original display carefully to be sure they match.
  • Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component.
  • Desolder the four solder pads from the lower left of the display to remove the sensor assembly cable.
  • The following step includes instructions for transferring this sensor to the new display assembly.
Examinez votre pièce de rechange et votre écran d'origine pour vous assurer qu'ils correspondent.
Votre écran de remplacement peut manquer le capteur de marche/veille, qui est nécessaire pour l'utilisation de Smart Cover. Si vous souhaitez garder cette fonction, vous devrez transférer le composant.
Dessoudez les quatre plaques de soudure en bas à gauche de l'écran pour enlever la nappe de l'ensemble capteur.
L'étape suivante inclut des instructions pour transférer ce capteur vers le nouvel écran.
귀하의 기여는 오픈 소스 Creative Commons 인가 하에 허가되었습니다.
