주요 콘텐츠로 건너뛰기
uAttend bn6000 Speaker Replacement
필요한 것
  1. uAttend bn6000 Speaker Replacement, Disassembly: 1 단계, 이미지 1/1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Speaker Replacement: 2 단계, 이미지 1/1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove the two 5mm PH #1 screws from the speaker assembly, by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
    • Remove the speaker assembly from the unit, by lifting the speaker up and away from the housing.
  4. uAttend bn6000 Speaker Replacement: 4 단계, 이미지 1/2 uAttend bn6000 Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the bundled cable carefully, by prying up on it with the plastic opening tool.
    • Carefully remove speaker from unit by pulling it up and away from housing.
결론
abdullah sumait
회원 가입일: 09/20/17
419 평판
안내서 4개 작성하였습니다
Idaho State University, Team S4-G1, Watkins Fall 2017 Idaho State University, Team S4-G1, Watkins Fall 2017 회원
ISU-WATKINS-F17S4G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 9
전체 시간: 107
