필요한 것
Insert a small screwdriver into the holes the screws were removed from in the previous step to unclip the keyboard.
Using a plastic spudger, flip up the retaining latch on the ZIF connector securing the blue ribbon cable, then slide the cable straight out from the connector.
To release the orange flex cable, use the tip of a spudger to slide the latches on either side in the direction indicated by the arrows, then pull the cable straight out from the connector.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
