주요 콘텐츠로 건너뛰기
why! N240BU Keyboard Replacement
필요한 것
  1. why! N240BU Keyboard Replacement, Battery: 1 단계, 이미지 1/2 why! N240BU Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Keyboard Replacement, Access to main components: 2 단계, 이미지 1/2 why! N240BU Keyboard Replacement, Access to main components: 2 단계, 이미지 2/2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU Keyboard Replacement: 3 단계, 이미지 1/3 why! N240BU Keyboard Replacement: 3 단계, 이미지 2/3 why! N240BU Keyboard Replacement: 3 단계, 이미지 3/3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU Keyboard Replacement, The keyboard: 4 단계, 이미지 1/3 why! N240BU Keyboard Replacement, The keyboard: 4 단계, 이미지 2/3 why! N240BU Keyboard Replacement, The keyboard: 4 단계, 이미지 3/3
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  5. why! N240BU Keyboard Replacement: 5 단계, 이미지 1/3 why! N240BU Keyboard Replacement: 5 단계, 이미지 2/3 why! N240BU Keyboard Replacement: 5 단계, 이미지 3/3
    • Disconnect the connector circled in red in the direction of the arrow
결론
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Felice Suglia
회원 가입일: 06/15/13
30,731 평판
안내서 261개 작성하였습니다
댓글 2개
Thanks for the example. But where did you bought the keyboard? i can’t find it.
Marcos - 답글
Dear Sir,
thank you for your request. We are swiss keyboards, which you can order here:
''https://whyopencomputing.ch/fr/laptop-wh...
and we have a French AZERTY here:
''https://whyopencomputing.com/fr/laptop-w...
For other keyboards, please try by your local Clevo supplier.
Best regards.
Felice Suglia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 351
