주요 콘텐츠로 건너뛰기
why! N240JU Replacement motherboard
필요한 것
  1. why! N240JU Replacement motherboard, Battery: 1 단계, 이미지 2개 중 1개 why! N240JU Replacement motherboard, Battery: 1 단계, 이미지 2개 중 2개
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacement motherboard, Access to main components: 2 단계, 이미지 2개 중 1개 why! N240JU Replacement motherboard, Access to main components: 2 단계, 이미지 2개 중 2개
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacement motherboard: 3 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard: 3 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard: 3 단계, 이미지 3개 중 3개
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacement motherboard, SSD M.2 disk: 4 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard, SSD M.2 disk: 4 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard, SSD M.2 disk: 4 단계, 이미지 3개 중 3개
    • Locate the M.2 SSD in its slot.
    • Unscrew the fastening screw of the latter.
    • Lift and remove the SSD M.2 drive from its connector.
  5. why! N240JU Replacement motherboard, Hard disk (mass storage): 5 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard, Hard disk (mass storage): 5 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard, Hard disk (mass storage): 5 단계, 이미지 3개 중 3개
    • Locate the hard drive in its location.
    • Lift it slightly.
    • Finally remove it from its SATA connector.
  6. why! N240JU Replacement motherboard, BIOS stack: 6 단계, 이미지 2개 중 1개 why! N240JU Replacement motherboard, BIOS stack: 6 단계, 이미지 2개 중 2개
    • To reassemble your device, follow the instructions in reverse order.
    • Lift it gently and take it out of its place.
  7. why! N240JU Replacement motherboard, WLAN card: 7 단계, 이미지 2개 중 1개 why! N240JU Replacement motherboard, WLAN card: 7 단계, 이미지 2개 중 2개
    • Carefully unplug the MAIN and AUX antennas.
    • Unscrew the fixing screw with the Philips # 0 screwdriver. Then lift the chipset slightly and remove it from the connector.
  8. why! N240JU Replacement motherboard, RAM Memory: 8 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard, RAM Memory: 8 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard, RAM Memory: 8 단계, 이미지 3개 중 3개
    • Find and separate the spring blades that maintain the memory module in place (right).
    • Find and separate the spring blades that maintain the memory module in place (left).
    • Remove the memory module (RAM) from its connector.
  9. why! N240JU Replacement motherboard, The fan: 9 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard, The fan: 9 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard, The fan: 9 단계, 이미지 3개 중 3개
    • Remove the power cable from the fan.
    • Unscrew the two screws securing the fan.
    • Finally remove the fan and place it on your worktop.
  10. why! N240JU Replacement motherboard, The keyboard: 10 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard, The keyboard: 10 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard, The keyboard: 10 단계, 이미지 3개 중 3개
    • Unscrew the circled screws in green and red
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  11. why! N240JU Replacement motherboard: 11 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard: 11 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard: 11 단계, 이미지 3개 중 3개
    • Disconnect the connector circled in red in the direction of the arrow
  12. why! N240JU Replacement motherboard, Motherboard: 12 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard, Motherboard: 12 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard, Motherboard: 12 단계, 이미지 3개 중 3개
    • Locate the two flat cables and remove them carefully.
  13. why! N240JU Replacement motherboard: 13 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard: 13 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard: 13 단계, 이미지 3개 중 3개
    • Locate the five connectors on the motherboard
    • Unplug all connectors
  14. why! N240JU Replacement motherboard: 14 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard: 14 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard: 14 단계, 이미지 3개 중 3개
  15. why! N240JU Replacement motherboard: 15 단계, 이미지 2개 중 1개 why! N240JU Replacement motherboard: 15 단계, 이미지 2개 중 2개
    • Unscrew the four screws circled in red
    • Lift the motherboard by taking it through the radiator
  16. why! N240JU Replacement motherboard: 16 단계, 이미지 3개 중 1개 why! N240JU Replacement motherboard: 16 단계, 이미지 3개 중 2개 why! N240JU Replacement motherboard: 16 단계, 이미지 3개 중 3개
    • Disconnect the two connectors circled in red
결론
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 469
