주요 콘텐츠로 건너뛰기
why! N240JU Replacing the LCD screen
필요한 것
  1. why! N240JU Replacing the LCD screen, Battery: 1 단계, 이미지 2개 중 1개 why! N240JU Replacing the LCD screen, Battery: 1 단계, 이미지 2개 중 2개
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Replacing the LCD screen, Access to main components: 2 단계, 이미지 2개 중 1개 why! N240JU Replacing the LCD screen, Access to main components: 2 단계, 이미지 2개 중 2개
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Replacing the LCD screen: 3 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 3 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 3 단계, 이미지 3개 중 3개
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Replacing the LCD screen, LCD screen: 4 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen, LCD screen: 4 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen, LCD screen: 4 단계, 이미지 3개 중 3개
    • In order to remove the LCD screen, you must remove the connection cables from the Wi-Fi chipset.
    • Then locate the two connectors on the LCD screen.
    • Disconnect the first connector.
  5. why! N240JU Replacing the LCD screen: 5 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 5 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 5 단계, 이미지 3개 중 3개
    • Peel off the tape from the second connector.
    • Then disconnect the second connector.
    • Locate the SSD M.2 drive.
  6. why! N240JU Replacing the LCD screen: 6 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 6 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 6 단계, 이미지 3개 중 3개
    • Then dismount this disk because it must release the connection cables of the Wi-Fi chipset.
    • Free Wi-Fi connection cables now
    • Now locate the two screws that secure the screen to the rest of the Laptop (fan side)
  7. why! N240JU Replacing the LCD screen: 7 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 7 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 7 단계, 이미지 3개 중 3개
    • Now locate the two screws that secure the screen to the rest of the Laptop (the other side).
    • Then lift the Laptop as shown in the second image of this step.
    • Unscrew the first screw.
  8. why! N240JU Replacing the LCD screen: 8 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 8 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 8 단계, 이미지 3개 중 3개
    • Then unscrew the second screw.
    • Rest the Laptop as shown in the second image of this step and unscrew the third screw.
    • Then the fourth screw.
  9. why! N240JU Replacing the LCD screen: 9 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 9 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 9 단계, 이미지 3개 중 3개
    • With the four screws unscrewed, separate the screen from the rest of the Laptop. Note that the hinge remains attached to the screen.
    • On the screen near the hinge now locate the two caches screws on the left.
    • Then look for those on the right.
  10. why! N240JU Replacing the LCD screen: 10 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 10 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 10 단계, 이미지 3개 중 3개
    • Now remove the screw covers near the left hinge.
    • first on the right side of the hinge.
    • then on the left side.
  11. why! N240JU Replacing the LCD screen: 11 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 11 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 11 단계, 이미지 3개 중 3개
    • Repeat near the right hinge
    • .Now return to the hinge on the left side and unscrew the outer screw.
  12. why! N240JU Replacing the LCD screen: 12 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 12 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 12 단계, 이미지 3개 중 3개
    • Then unscrew the inner screw.
    • Repeat on the side of the right hinge.
  13. why! N240JU Replacing the LCD screen: 13 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 13 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 13 단계, 이미지 3개 중 3개
    • You can now gently unclip the screen cover.
    • Locate the left hinge screw cover.
    • Locate the right hinge screw cover.
  14. why! N240JU Replacing the LCD screen: 14 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 14 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 14 단계, 이미지 3개 중 3개
    • Gently remove the screw cover on the left hinge.
    • Also remove the screw cover on the right hinge.
    • Once the screw caps are removed you will see the fixing screws.
  15. why! N240JU Replacing the LCD screen: 15 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 15 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 15 단계, 이미지 3개 중 3개
    • Now unscrew the screw on the left hinge.
    • Then unscrew the screw on the right hinge.
    • Once this is done you can now remove the hinge cover (left).
  16. why! N240JU Replacing the LCD screen: 16 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 16 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 16 단계, 이미지 3개 중 3개
    • Left hinged cover removed.
    • Then remove the cover from the right hinge.
    • Right hinge cover removed.
  17. why! N240JU Replacing the LCD screen: 17 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 17 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 17 단계, 이미지 3개 중 3개
    • once these operations are done you see the LCD screen ready to be dismounted.
    • Now locate the screws that secure the LCD screen to the bracket and unscrew them. Two on the left.
    • Two on the right.
  18. why! N240JU Replacing the LCD screen: 18 단계, 이미지 3개 중 1개 why! N240JU Replacing the LCD screen: 18 단계, 이미지 3개 중 2개 why! N240JU Replacing the LCD screen: 18 단계, 이미지 3개 중 3개
    • Once the screws are unscrewed, lift the LCD screen gently and flip it over.
    • You will then see the connection cable of the screen.
    • Locate its connector.
  19. why! N240JU Replacing the LCD screen: 19 단계, 이미지 2개 중 1개 why! N240JU Replacing the LCD screen: 19 단계, 이미지 2개 중 2개
    • Disconnect the cable.
    • And here you can now put it on your work plan.
결론
To reassemble your device, Follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 4
전체 시간: 550
