주요 콘텐츠로 건너뛰기
why! W650SZ LCD Screen Replacement
필요한 것
  1. why! W650SZ LCD Screen Replacement, Battery: 1 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Battery: 1 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ LCD Screen Replacement, Remove the Bezel: 2 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Remove the Bezel: 2 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Remove the Bezel: 2 단계, 이미지 3개 중 3개
    • Although the photos are shown without a keyboard, it is not necessary to remove the keyboard to replace the screen.
    • Gently insert your fingernail between the display bezel and the LCD.
  3. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): 3 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): 3 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): 3 단계, 이미지 3개 중 3개
    • Working your way around the frame, unclip the mounting points of the frame surrounding the LCD screen.
  4. why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): 4 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): 4 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Remove the Bezel (continued): 4 단계, 이미지 3개 중 3개
    • Remove the bezel surrounding the LCD.
  5. why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: 5 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: 5 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Remove the Screws Securing the LCD: 5 단계, 이미지 3개 중 3개
    • Remove the two upper mounting screws securing the LCD to the lid.
    • Remove the two lower mounting screws.
  6. why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: 6 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: 6 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Separate the LCD from the Display: 6 단계, 이미지 3개 중 3개
    • Cover the keyboard with a cloth, then carefully lower the LCD screen onto the keyboard.
  7. why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: 7 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: 7 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Disconnect the LCD Cable: 7 단계, 이미지 3개 중 3개
    • Note the location of the LCD screen connector.
  8. why! W650SZ LCD Screen Replacement, Remove the Connector Tape: 8 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: 8 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Remove the Connector Tape: 8 단계, 이미지 3개 중 3개
    • Using the plastic tab, peel back the tape securing the LCD cable the panel connector.
  9. why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: 9 단계, 이미지 3개 중 1개 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: 9 단계, 이미지 3개 중 2개 why! W650SZ LCD Screen Replacement, Unplug the LCD and Remove the Screen: 9 단계, 이미지 3개 중 3개
    • Unplug the connector.
    • The LCD screen can now be removed.
결론
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
Jerry Wheeler님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 257
