소개
How to replace the Intel Centrino wireless chipset card.
필요한 것
Déverrouiller le loquet de fixation de la batterie.
Déverrouiller le verrou de fixation de la batterie situé à gauche.
Retirer le bloc accumulateur de son logement.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Carefully unplug the MAIN and AUX antennas.
Remove the retaining screw with a Phillips #0 screwdriver.
Lift the chipset card and remove it from the mSATA connector.
다음 번역가들에게 특별히 감사 드립니다:
100%
Jerry Wheeler님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
