제품 정보
설명
This MacBook 12" Retina (Early 2016-2017) replacement battery is what you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5210 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
- Battery adhesive is preinstalled to improve the quality of your repair.
Battery degradation is an inevitable part of your MacBook's lifespan, extend it with this new replacement battery compatible with MacBook 12" Retina (Early 2016-2017). Factory-installed MacBook 12" Retina (Early 2016-2017) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
키트 콘텐츠
- New MacBook 12" Retina (Early 2016-2017) Battery
- iFixit Adhesive Remover
- Safety Glasses
- Nitrile Gloves (2)
- Berkshire PRO Wipe 880
- Battery Blocker
- Spudger
- iFixit Opening Tool
- iFixit Opening Picks (Set of 6)
- Plastic Cards
- Angled Tweezers
- Precision Bit Driver
- 4 mm Precision Bits:
- Phillips #00
- Pentalobe P5
- Torx T5
- Torx Security TR6
호환성
- MacBook 12" Retina A1534 Early 2016 to 2017
명세서
호환성
고객 리뷰
