부품 Mac MacBook 13" Core 2 Duo Hard Drives SATA
상점
모델명을 모르십니까? Mac ID 찾기
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8.99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7.99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
US$114.99부터
1 TB SSD Hybrid 2.5" Hard Drive / Part Only
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive Hybrid, 5400 RPM / 2.5" wide x 9.5mm tall / 1 TB Unformatted
US$84.99부터
500 GB SSD / Part Only
500 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 525 GB Unformatted
US$139.99부터
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
US$9.99
250 GB SSD / Part Only
250 GB SSD
SATA 6.0 Gb/s interface for Intel Macs / Solid State Drive / 2.5" wide x 7mm tall / 275 GB Unformatted
US$94.99부터
MacBook 13.3" LCD Panel
Replace your cracked or damaged MacBook LCD with this part. This part is compatible with all 13.3" (1280x800) MacBooks (excluding MacBook Unibody and MacBook Air).
US$49.99
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
US$54.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
US$24.99
제품 보기 73개 중 1 - 10개
기기 정보
The Core 2 Duo MacBooks feature beefier processors, thanks to the Core 2 Duo chipset.
A total of 3 GB of memory (using a 2 GB RAM chip and a 1 GB RAM chip) will max out your machine's capacity. The biggest hard drive that can currently be put into these laptops is the 500 GB 7200 RPM SATA hard drive. The 8x SuperDrive is the fastest optical drive for these models and will make creating DVDs a whiz. You can also upgrade the upper case to the Penryn/Santa Rosa version with the new keyboard layout (including iTunes controls)!
There is one main variation within these models. Your machine may be a Energy Star-equipped or non-Energy star version. This affects the battery connector and logic board. See photos and part descriptions on the non-Energy Star or Energy Star battery connector/sleep sensors for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your model above or browse all compatible parts to find what you need to fix your laptop!
