기기를 고치세요
수리할 권리
부품 & 도구
MacBook 13" Unibody (A1342 Late 2009-Mid 2010) Replacement Battery
  • MacBook 13" Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Fix Kit
  • MacBook 13" Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
US$84.99
US$84.99
제품 재입고 메시지를 보내드리겠습니다.
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
제품 정보
설명
설명
This MacBook Unibody (Model No. A1342 Late 2009/Mid 2010) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5510 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook's lifespan, extend it with this new replacement battery compatible with MacBook Unibody (A1342 Late 2009-Mid 2010). Factory-installed MacBook Unibody (A1342 Late 2009-Mid 2010) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
키트 콘텐츠
키트 콘텐츠
호환성
호환성
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
명세서
명세서
Part #:
661-5391
Model #:
A1331
Watt Hours:
63.5 Wh
Voltage:
10.95 V
Milliamp Hours:
5800 mAh
Manufacturer:
Aftermarket
호환성
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
고객 리뷰
