기기를 수리하세요
수리할 권리
상점
MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
US$39.99
US$39.99
제품 정보
설명
설명
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
부품 조립체가 포함하는
부품 조립체가 포함하는
  • Fan
  • Attached Heat Sink
호환성
호환성
  • 1.6 or 1.8 GHz Original MacBook Airs
명세서
명세서
Part #:
922-8316
설치 동영상
호환성
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
수리 경험담
사용자 아바타
내 문제
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
나의 수리
Changed the fan. Cleaned the inside of the laptop from dust…
내 조언
Clean the inside at least twice a year…
사용자 아바타
내 문제
Existing fan was loud
나의 수리
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
내 조언
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
사용자 아바타
내 문제
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
사용자 아바타
내 문제
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
나의 수리
The repair took abo . . .
더 보기
