MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
  • MacBook Pro 13" Retina (Late 2012-Early 2013) Display Assembly
US$499.99
US$499.99
제품 정보
설명
설명
This Late 2012 to Early 2013 MacBook Pro 13" Retina replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
An aging or battered laptop display may suffer a flickering image, dead pixels, or a dim backlight. Surface scratches can further degrade the image and a dented or warped case may pinch the display causing bright spots. Eliminate these flaws with a replacement LCD display assembly. Our displays are individually tested and guaranteed to function perfectly.
부품 조립체가 포함하는
부품 조립체가 포함하는
  • 2560 x 1600 13.3" Retina LCD Screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
호환성
호환성
  • MacBook Pro 13" Retina A1425 Late 2012 to Early 2013
명세서
명세서
Part #:
661-7014
Resolution:
2560x1600
Diagonal Size:
13.3"
호환성
MacBook Pro 13" Retina Display Early 2013
A1425 (EMC 2672) 2.6 GHz
A1425 (EMC 2672) 3.0 GHz
MacBook Pro 13" Retina Display Late 2012
A1425 (EMC 2557) 2.5 GHz
A1425 (EMC 2557) 2.9 GHz
수리 경험담
사용자 아바타
내 문제
Crack in display
나의 수리
Very good, the only difficult part was to replace the new display and connect it with the first 2 screws.
내 조언
사용자 아바타
내 문제
I carelessly put a small crack in my previous screen and after getting an estimate from a shifty guy at the Apple store I would have been better off replacing the whole Macbook. I'm in college and I need to save the money.
나의 수리
The process was smooth and easy with excellent steps and pictures to help buls . . .
사용자 아바타
내 문제
Cracked display.
나의 수리
Smoothly.
내 조언
Must have proper screwdrivers (Torx 2, 5, 6, 7, and 8, I believe).
사용자 아바타
내 문제
My old retina display was dying. I had a streak of dying pixels down the left side of my monitor
나의 수리
The replacement was simple thanks to IFIXIT! Before even cracking open the case I knew which tools I needed, the task at hand, and the basic time I would need to allot for the job. I swapped out my lid as . . .
사용자 아바타
내 문제
The screen was damaged when the laptop was dropped
나의 수리
Screen replaced
내 조언
I had someone experienced in repairing my laptop complete the repair. Very satisfied and happy with the outcome.
사용자 아바타
Phil Wymore's Story Photo #858008
내 문제
Cracked Retina display
나의 수리
It couldn't have been easier -- in fact it was actually fun. The tools were perfectly matched for each task and the instructions were very easy to follow.
내 조언
Don't be intimidated
사용자 아바타
jimpandolfo's Story Photo #901875
jimpandolfo's Story Photo #901873
jimpandolfo's Story Photo #901878
내 문제
Coating was coming off my retina screen.
나의 수리
The web site instructions were spot on! The repair was easy and fun to do. I had 0 issues. Thanks!!!
내 조언
As long as you follow the directions, it's an easy repair. Took me less than 30 minutes
더 보기
