MacBook Pro 13" Unibody and MacBook 13" Unibody Fan
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / New / Black
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Silver
  • MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Black
US$39.99
US$39.99
제품 재입고 메시지를 보내드리겠습니다.
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
제품 정보
설명
설명
Replace a broken, damaged, or otherwise underperforming fan for your MacBook Pro 13" Unibody (Mid 2010-Mid 2012) or MacBook 13" Unibody (all models) with this part.
부품 조립체가 포함하는
부품 조립체가 포함하는
  • Fan
  • Surrounding metal bracket
설치 동영상
수리 경험담
사용자 아바타
내 문제
The fan sounded like it was dying.
As I was leaving one day, it started running, and I was sure that someone was outside using a weedeater. Then I remembered it was winter and snow was everywhere, so that probably wasn't the case.
나의 수리
Pretty painlessly. I read some reviews hearing that it didn't go as w . . .
사용자 아바타
내 문제
I suppose my computer is ancient considering many machines are replaced at 2ish years. Anyway, fan was making terrible clicking/rattling sounds after a suffering a light drop from a low bed onto carpet.
나의 수리
Easy peasy, lemon squeezy.
내 조언
None. If you know how to use a screw driver, you can make this repair.
사용자 아바타
내 문제
The fan had been making a loud grinding noise. It also couldn't reach it's max RPM.
나의 수리
It was very straightforward.
내 조언
Be slow and patient; the connectors are very delicate. Also, keep track of the screws!
사용자 아바타
내 문제
Wife's Macbook Pro 13" fan stopped working
나의 수리
Literally took off the Phillips screws holding bottom cover, took 3 Torx 6 screws out, unplugged fan from board, took out fan, put new one in, plugged into board, put Torx 6 screws back in, and put Phillips back in. Worked like a charm.
내 조언
Screws had tiny bump o . . .
사용자 아바타
내 문제
The fan was getting noisy but still working. I knew its days were numbered
나의 수리
super easy. While i was in there I decided to upgrade the HD to an SSD also. With the tutorials on Ifixit it was all super easy.
내 조언
Don't be afraid to try repairs on your MacBook Pro. It's much easier than you think with the tutor . . .
사용자 아바타
내 문제
My MBP has been making this grinding noise that I originally thought was the HDD failing (again). Turned out it was the fan going bad. When I ran a YouTube video my CPU temperature spiked to high 80's and you could hear the fan screaming for mercy. lol :)
나의 수리
The most difficult part of the repair was wa . . .
사용자 아바타
내 문제
The fan had completely quit in my 2012 unibody macbook pro and as a result it was overheating and slowing the cpu to a crawl during taxing graphical work.
나의 수리
The new fan fit perfectly and works perfectly and silently. I'm far more confident in its brushless motor to hold up.
내 조언
The fans don't come with hard . . .
사용자 아바타
내 문제
My fan was making my MacBook sound louder than a blender!
나의 수리
Super easy and straight forward.
내 조언
Don't be afraid to make your own repairs. I recently also double the memory sticks on my MacBook and it is now nice and quiet and lightning fast. Having said the, do know your limitations.
사용자 아바타
내 문제
The fan was noisy, and it sounded like it was on the way out
나의 수리
All good until it came to levering the fan connector out with the spudger. Then -- as predicted in the instructions -- disaster! All four pins from the logic board sheared off, firmly in the fan connector. Fortunately my local computer tech . . .
사용자 아바타
내 문제
The fan was beginning to make a screeching racket and the mac case was getting hotter than it ever had before, then it went quiet and made no noise! So after conferring with a friendMacGuru I presumed that at least the fan could do with replacement immediately lest I need to replace the lot imminent . . .
더 보기
